detail level
COW Forums : Panasonic Cameras
Goran Myrendal
detail level
on Dec 16, 2008 at 7:17:42 pm
I have used Avid express pro to convert HD footage from my Panasonic HDX900 down to SD.
First I converted the sequens from 1080i/50 to DV25 PAL and then I tried to do a digital cut to dvcam. The result is a wery soft image.
I understand that the result of HD is sharper than SD. I guess the detail level should be set differently if the result should be shown in SD compared to HD
Could anyone give me some input here. How do you set the detail level if the result will be shown in SD and how do you set it if the result will be shown in HD?
Thank you
