25i PAL
COW Forums : Panasonic Cameras
Goran Myrendal
25i PAL
on Jun 25, 2008 at 8:03:40 pm
I just bought a Panasonic HDX900.
If I want to connect a non-linear editor to the DVCPRO output connector and edit the footage in 25i PAL, what format should I record the footage in?
The reson why 25i PAL is that I sometimes work with news.
john sharaf
Re: 25i PAL
on Jun 25, 2008 at 8:07:26 pm
Goran,
News is more likely shot at 50i frame rate. 25fps is a progressive rate that duplicates identical frames to replicate a "film look". News is usually shot to look more "live" which 50i does by creating a new field every half frame.
JS
Goran Myrendal
Re: 25i PAL
on Jun 25, 2008 at 9:10:47 pm
Thanks for your quick reply!
I have a avid program that I have used to edit DVCAM earlier. When I select format I have selected 25i PAL.
I thought that 25 in 25i PAL stands for 25 megabit per second? What do you think about that?
