Workflow from Varicam to Final Cut
COW Forums : Panasonic Cameras
Natasha Arciniega
on May 23, 2008 at 2:48:51 pm
Hello!
Can someone explain the best and easiest way to Capture footage from the Varicam to Final Cut with ratio 25 fps.
We have mananged to capture the footage using a Panasonic Deck AJ - HD1400A
but could only get the footage in at 60fps.
I am in urgent need of some advice. Thanks Natasha
gary adcock
Re: Workflow from Varicam to Final Cut
on May 23, 2008 at 5:27:43 pm
[Natasha Arciniega] "Can someone explain the best and easiest way to Capture footage from the Varicam to Final Cut with ratio 25 fps. but could only get the footage in at 60fps."
Before we start- since you are in PAL land
what FCP/ OS / QT versions
on what computer?
How was the footage shot (sounds like 25/60- but was the camera set to 59.94 or 60hrz)
how are you ingesting the footage?
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
