Playing out 24p(over60hz) footage as 24p(over59.98hz) using AJ-HD1400
COW Forums : Panasonic Cameras
Ian Grey
on May 1, 2008 at 4:15:27 pm
I was wondering if anyone had an insight into a way im thinking of solving a problem.
I got DVCPROHD tapes shot at 24p (not 23.97) on the 60hz setting on the camera.
I notice that with FCP it doesn't have a true 720/24p project setup for DVCPRO HD. The kona card setups are only 720/23.97.
I was wondering what would happen if i played my 24p/60hz tapes with the AJ-HD1400 deck set to 24p/59.98hz. Would the footage come out of the deck at all and if it did would it be in a correct format to edit with in FCP.
With this workfloe i appreciated the BWF recording on the set will drift sync and need to be re-timed by the sound guys but my problem at the moment is getting the footage into FCP (Or even Avid as I have access to both systems)
Im based in the UK and would appreciated any advice or alternative to this workflow im thinking about
Best Regards,
Ian Grey
john sharaf
Re: Playing out 24p(over60hz) footage as 24p(over59.98hz) using AJ-HD1400
on May 1, 2008 at 4:18:38 pm
Yes, the footage will come out of the deck, but the audio will be out of sync. There are various workarounds, but you'll still have to manually sync the sound back up.
JS
