Upconverting beta footage with 1200a
COW Forums : Panasonic Cameras
fine productions
on Apr 7, 2008 at 9:27:08 pm
I need to upconvert beta sp footage and DV footage using my 1200A deck. My question is what is the best workflow. Can I basically use the deck as a go between without recording to Panasonic tape or do I have to record to tape and then capture that footage. Also any advice on menu setups would be really appreciated.
john sharaf
Re: Upconverting beta footage with 1200a
on Apr 8, 2008 at 4:59:22 pm
Fine,
The 1200A and 1400 decks will only upconvert through the firewire input port, do you should have no trouble with the DV materials, but as a work around, you'd need to dub the Beta to DV then upconvert.
JS
