Kona IO HD SDI from AJ-HD150 or 1200A by firewire--which?
COW Forums : Panasonic Cameras
pSquared
on Jan 28, 2008 at 8:40:15 pm
Can capture from either Panasonic 1200A by fire wire, or from AJ-HD150 from HD SDI thru
Kona I/O. Usually do the 1200A route, but need to output best quality possible frame grabs,
and wondering if there's a noticeable/visible quality diff between the two.
File size not an issue.
Thanks.
p2
gary adcock
Re: Kona IO HD SDI from AJ-HD150 or 1200A by firewire--which?
on Jan 28, 2008 at 9:23:33 pm
[pSquared] "need to output best quality possible frame grabs,
and wondering if there's a noticeable/visible quality diff between the two. "
yes there is a sizable difference between a frame grab from a uncompressed capture and a firewire capture.
the uncompressed will look and reproduce better.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
pSQUARED Powell
Oops. Meant KONA 2 HD...
on Jan 28, 2008 at 9:37:26 pm
Sorry. I/O's in the other room.
Thanks gary.
p2
