Working with AF 100 shot at 60fps ... ISSUES!
COW Forums : Panasonic Cameras
Phil Bucci
on Mar 22, 2013 at 6:43:39 pm
Hi all. I'm cutting a small project and there were a lot of freebies done on this one. So none of us including the DP has ever worked with the AF 100. They shot 1080 at 23.98. All that is fine. There are some shots done at 60fps and this is the problem. Through the log and transfer process in fcp it imports the 60 clips as 29.97. Does any one know the proper work flow to get the slow mo right?
Phil
Noah Kadner
Re: Working with AF 100 shot at 60fps ... ISSUES!
on Mar 23, 2013 at 10:02:11 pm
Make sure that the clips are not being conformed to the current sequence settings. This might help- http://www.calgaryfcpug.com/final-cut-studio-2/15380-fcp-6-mixed-format-edi...
Noah
Call Box Training.
Featuring the Panasonic GH2 and Panasonic AC160/130.
Phil Bucci
on Mar 30, 2013 at 2:02:41 am
Hey Noah, the problem actually occurs before even cutting into the time line. The clips that were shot at 60 fps when imported are now 29.97 when you look at their frame rate. There mostly likely was a mis cue on set im just trying to rule everything out on my end. If no one else is having issues in FCP7 and using log and transfer to import these clips properly then I do think some thing went wrong on set. As far as I can tell this should be a simple import. Would it screw anything up if 2 different frame rates were on the same card for import?
Phil
Erik Naso
on Mar 31, 2013 at 5:40:57 am
looks like the 60fps shots are 29.97. FCP wouldn't change the frame rate during log and transfer.
Blog http://www.eriknaso.com
My Vimeo Page http://vimeo.com/user626030
Follow me on Twitter @ErikNaso
