Questions about NP-1 style batteries for DVCPRO50 camcorder
COW Forums : Panasonic Cameras
Ewan Cutler
on Jan 26, 2013 at 1:05:53 am
Hi There
Not sure if this is the correct forum for it or not.
I'm wondering whether the camera I use is combatible with these batteries: http://www.globalmediapro.com/dp/A00XK8/Globalmediapro-Li65N-Lithium-ion-Ba...
I've got a AJ-D910WA DVCPRO50 Camera which has a Sony NP-1 battery adapter on it. We're currently using these batteries to power the camera: http://master-instruments.com.au/products/55577/SP1B.html
However with the amount of field production we do, the batteries are running for average of 15 mins, before dropping down to 5 min or less after a few charges. (We discharge them before recharging)
I've attached a picture of the camera manual below, according to this would my camera be able to support these batteries??: http://www.globalmediapro.com/dp/A00XK8/Globalmediapro-Li65N-Lithium-ion-Ba...
Thanks in advance.
Thomas Alexander
Re: Questions about NP-1 style batteries for DVCPRO50 camcorder
on Jan 26, 2013 at 11:45:21 am
You need an external or alternative way of powering your camera. Check out Anton Bauer Gold Mount Plate and a battery that has the same voltage with the current you use and it will last long time. Using cheap batteries will only make it difficult.
Thomas Alexander | Independent Cinematographer
Soulman Films | Nicosia Cyprus | +357-97697640
