Static audio noise on HMC150
COW Forums : Panasonic Cameras
Megan Wieser
on Apr 4, 2012 at 7:20:56 pm
I've ordered two different Panasonic HMC 150s for work use. Both have had the same problem -- even when I have the internal mic off and nothing/no mics plugged in to inputs 1 and 2 I still get a static noise when I record. If I have all of that off you would think if i recorded for 10 seconds and stopped and played it back I would hear nothing. instead i get this static sound playing back. Any idea what is causing that? or how i can fix it?
Guy McLoughlin
Re: Static audio noise on HMC150
on Apr 9, 2012 at 5:09:19 pm
When you record, do you have the mic channel levels set to zero ?
