Panasonic audio settings, I'm confused...
COW Forums : Panasonic Cameras
Christopher Coffyn
on Mar 23, 2012 at 7:45:51 pm
Although this is in direct reference to our AG160P, according to our sales rep a lot of other Panasonic cameras have the same setup.
Having been shooting with Sony cameras for years I'm trying to get a handle on how Panasonic does the audio.
1. I can't seem to tell any difference audibly between the "auto" setting (AGC?) on the Ch1/2 switches and the internal menu "Limiter" setting.
2. Even with the camera set to auto or with the limiter turned on, it does not seem to be aggressive enough to keep the audio from distorting with louder sounds.
FYI in our traditional one person crew, we normally shoot general ambient/atmo audio with channel 1 set to manual and channel 2 to some kind of AGC setting as backup.
Noah Kadner
Re: Panasonic audio settings, I'm confused...
on Mar 27, 2012 at 9:11:59 pm
Yeah you have to be really careful with your sounds- if you're peaking too much you need to consider manually riding the levels or an outboard mixer. No limiter is going to catch every overmod.
Noah
Call Box Training.
Featuring the Panasonic GH2 and Panasonic AC160/130.
Christopher Coffyn
on Mar 28, 2012 at 3:31:56 pm
Thanks Noah!
Do you know if the "audio" setting switch on the side of the camera and the internal menu limiter functions differently? The manual really adds no clarity.
Noah Kadner
on Mar 28, 2012 at 11:00:54 pm
Limiter and automatic gain control are not the same thing. Limited imposes a hard upper limit to wherever you set your audio, AGC attempts to ride the entire audio level up and down- which generally sounds quite bad as it also rides the ambience level up too.
Noah
Call Box Training.
Christopher Coffyn
on Mar 28, 2012 at 11:32:00 pm
Thanks Noah!
