Can I feed two monitors at once, one via composite and one via HDMI?
COW Forums : Panasonic Cameras
Noam Osband
on Jul 26, 2011 at 6:31:27 pm
I want to feed two monitors at once with my HMC-150. I want to use the HDMI output for one and the composite output for the other. Can i use both at the same time? I'm using it to connect to two different machines, one that has an HDMI input and one with a composite input, so a device that let's me create two HDMI channels - like this http://www.bhphotovideo.com/c/product/623899-REG/Kanex_HDMISP2_HDMISP2B_1x2... - doesn't solve the problem.
John Fishback
Re: Can I feed two monitors at once, one via composite and one via HDMI?
on Jul 31, 2011 at 9:55:47 pm
I believe both outputs are active at the same time. It's easy to test as you have the camera. Of course the quality of the two signals (HDMI vs. composite) will be noticeably different. Using the component out will get you closer to the HDMI out than the composite.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
