Color Correcting P2 cards on set
COW Forums : Panasonic Cameras
Christian Stoehr
on Jun 20, 2011 at 4:39:42 pm
What are DIT`s using to color correct P2 footage on set ? They are shooting on a Panasonic AF100 ?
I assume loading it into FCP takes to long
John Fishback
Re: Color Correcting P2 cards on set
on Jun 20, 2011 at 9:52:08 pm
FCP will ingest P2 relatively quickly on its own and Calibrated's MXF Import allows instant access to P2 in any QT program. Color grading could then happen in FCP with various plugins or in Color. That said, the AF100 isn't a P2 camera. It records using AVCCAM. That can be transcoded into FCP as ProRes with Log & Transfer and I think ClipWrap will also work (and probably is faster).
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
