DVX100 FW out to KiPro
COW Forums : Panasonic Cameras
Tom Case
on Apr 14, 2011 at 8:15:46 pm
Anyone tried DVX100 firewire out to AJA KiPro? Is the FW out clamped? Will i get better than DV 25megabit bit rate on recording to SD ProRes via KiPro?
Steve Eisen
Re: DVX100 FW out to KiPro
on Apr 14, 2011 at 8:53:10 pm
You can not connect the DVX to the KiPro via firewire. There isn't even an analog input.
You would need an analog (composite) to HDMI or analog (composite) to SDI adapter.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Tom Case
on Apr 14, 2011 at 9:03:11 pm
So the firewire 400 & 800 connectors on the kipro don't function as input/output I guess?
Noah Kadner
on Apr 15, 2011 at 3:45:09 pm
Correct those are for transfer to your computer as data, not Firewire video. KiPro is not really applicable to a camera like the DVX100 to be honest. It's meant more for HD cameras with more aggressive compression codecs. At 25 mbit for just standard definition, DV is a lot closer to 'uncompressed' than most HD codecs in use today all things being relative.
Noah
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and Canon 7D.
