hvx200 and xha1; a way to look the same?
COW Forums : Panasonic Cameras
chris iuliano
on Apr 10, 2011 at 6:28:37 am
So here is my dilemna. I started a project and was using the xha1, but i no longer have use of that camera so I have to shoot the rest with the hvx200. The XH was set to 1080/60i 29.97 fps with a 1/60ss. I figured I could just set the hvx200 to the same settings, only for some reason it won't let me make the shutter speed 1/60, the lowest it will go 1/100. What im wondering is if i make it 1080/30p 30 fps and 1/60ss will it look the same?
Noah Kadner
Re: hvx200 and xha1; a way to look the same?
on Apr 10, 2011 at 7:19:29 pm
30p and 60i cannot be definition look remotely similar. I'd suggest finding a more common frame rate- such as 60i or 24p. That is if you're expecting a visual match.
Noah
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and Canon 7D.
