Turn Your AF100 into an ENG Camera
COW Forums : Panasonic Cameras
Guy McLoughlin
on Mar 29, 2011 at 6:36:10 pm
Very interesting idea...
Using 2/3″ Lenses on the Panasonic AF100
Rafael Amador
Re: Turn Your AF100 into an ENG Camera
on Mar 30, 2011 at 9:41:41 am
Hi Guy,
Great tutorial.
Thanks for bring it here.
rafael
PS: You have been nominated my personal AF-100 adviser :-)
http://www.nagavideo.com
Rafael Amador
@ Guy
on May 4, 2011 at 12:14:53 pm
Hi guy,
I've been thinking about this idea.
Old Betacam lenses are 2/3.
What about those lenses?
There are lot of them (Fuji, Canon) and very cheap.
rafael
Guy McLoughlin
Re: @ Guy
on May 4, 2011 at 5:41:17 pm
To use a 2/3" lens you will need something like the AbelCine HDx2 B4/PL Optical Adapter which doubles the focal-length and enables the lens to fully cover the much bigger m4/3 sensor.
I expect that this optical adapter is not cheap.
Rafael Amador
Re: @ Guy
on May 4, 2011 at 6:44:42 pm
[Guy McLoughlin] "To use a 2/3" lens you will need something like the AbelCine HDx2 B4/PL Optical Adapter which doubles the focal-length and enables the lens to fully cover the much bigger m4/3 sensor."
Guy, many of these Betacam lenses have "duplicator".
I don't know much, but a 2/3 lens is a 2/3 lens for HD and for SD. The difference may be that in the SD the lens is framed for 4x3 and in the HD for 16x9.
The thing is to know if with the same adapter those lenses would work.
HD lenses are great but too expensive.
Don't know if I'm saying a "bêtise".
Guy McLoughlin
Re: @ Guy
on May 4, 2011 at 8:44:20 pm
I think you will have to test, as I can`t imagine that it is this easy, otherwise more people would be using these old lenses, and AbelCine could not charge a lot for their optical duplicator.
