GH2 card file structure for FCP L&T
COW Forums : Panasonic Cameras
Chad Smith
on Feb 21, 2011 at 5:19:53 pm
So like many of us I am thinking of getting a GH2. Looking around on the web and getting some native mts files downloaded. I would like to bring these native files into FCP 7 and see how they look. However the files that I have downloaded are not in the file structure that FCP needs to see them in. I have tried putting the mts files in the following structure however FCP does not see them.
PRIVATE > AVCHD > BDMV > STREAM > 120110.MTS
How can I load the native .MTS files into the FCP L&T window for conversion to pro res?
Noah Kadner
Re: GH2 card file structure for FCP L&T
on Feb 22, 2011 at 6:28:39 am
You need the entire image from a card- not just the MTS. Search for GH2 card images- that's what you need.
Noah
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Canon 5D Mark II and 7D.
Chad Smith
on Feb 22, 2011 at 2:05:34 pm
Thanks Noah YES! that is the information I am looking for. Have spent a few hours trying to track this information down and the post from above is as far as I have gotten. Any leads on how I can obtain this information would be great. I am assuming that I just need the proper series of folders like with the Canon 7D files. THANKS!
Peter J. DeCrescenzo
on Feb 23, 2011 at 7:45:05 am
Although I don't recommend it as a project workflow, just as an FYI:
A GH2 camera-original AVCHD ".MTS" file can be "re-wrapped" to a QuickTime-playable ".M4V" file (without re-compression) using the free Rewrap2M4V & ClipWrap software, as discussed here:
http://discussions.apple.com/thread.jspa?threadID=2380085&ts%20tart=0
Using the above software, even a large MTS file can be re-wrapped in a few seconds simply by drag & dropping the MTS onto the Rewrap2M4V icon.
FYI: The free VLC software can play almost all video file types, including GH2 MTS files:
http://www.videolan.org/
For "real" projects, I strongly recommend transcoding AVCHD .MTS files to ProRes either using FCP's standard Log & Transfer feature or Compressor. Cheers.
http://www.peterdv.com
Chad Smith
on Feb 23, 2011 at 4:23:33 pm
Peter - Thanks much that did the trick!
