How much time while overcranking?
COW Forums : Panasonic Cameras
Rich Sims
on Jan 18, 2011 at 3:46:00 am
Hello everyone,
Could anyone fill me in on how much run time I will see from a 16GB card running 60 fps? Just want to make sure I'm covered for an upcoming shoot. I realize I can have two in but still need to have a plan in place.
FYI, just finished a shoot with the camera but no high speed. We really loved the look.
Rich
Rich Sims
Re: How much time while overcranking?
on Jan 19, 2011 at 2:48:18 am
Hi all,
Found the answer and thought I'd let people know. Apparently it doesn't matter if you're shooting slow motion or not. Recording time remains the same. So 16GB gives you 1 hour 30 minutes.
Take care,
Rich
Guy McLoughlin
on Jan 19, 2011 at 7:50:02 pm
...Not trying to be a "shirt" disturber, but I have read that the AF-100 records at a 50 percent higher data-rate when shooting 60 FPS over-crank video, which roughly puts it at about 35 Mbps.
This means that a 16 GB SDHC card would only record about 60 minutes of 60 FPS over-crank footage, that would play back as 150 minutes of slow-motion 24P.
Over-crank also requires Class 10 memory cards, and does NOT record any sound while shooting.
Rich Sims
on Jan 19, 2011 at 7:59:25 pm
Hi Guy,
Not "shirt" disturbing at all. I was actually thinking how could this be and I haven't had my hands on the camera long enough to do a test. We're shooting over the next few days so if I get an idea than I'll post my findings.
Thanks for jumping in.
Take care,
Rich
Rafael Amador
on Jan 24, 2011 at 4:54:02 pm
[Guy McLoughlin] "...Not trying to be a "shirt" disturber, but I have read that the AF-100 records at a 50 percent higher data-rate when shooting 60 FPS over-crank video, which roughly puts it at about 35 Mbp"
If the camera process at just a 50% higher data-rate when overcranking, the resulting file will will be "sub-standard".
When overcranking 30/60, the camera needs to process at double data-rate (x2). When you overcranck 24/60 the data-rate must be "x2.5". The resulting file should always be standard for the format.
That's makes that your slowmo picture from overcranking (60/30/24) will be better than the picture you get conforming p60 to p30 or p24.
rafael
http://www.nagavideo.com
Guy McLoughlin
on Jan 24, 2011 at 5:25:23 pm
Yes, ideally the data rate should be 2.5x the standard rate, but from what I've read it's only a 50 percent increase.
The few samples I've seen appear to be OK, though I don't know what would happen if you were trying to record a detailed high-speed event.
Vitaliy Kiselev ( creator of the GH-1 Hack ) recently posted on the DVXUSER site that the firmware to the AF-100 appears to be completely open, and thus he should have little trouble hacking the AF-100 firmware once he modifies the programming in his processor model. So there is the chance that down the road an AF-100 Hack could increase the data-rate for regular filming and overcranking.
Vitaliy Kiselev: Good-news-about-AF100-firmware
