HMC150p
COW Forums : Panasonic Cameras
Chuck Bolland
HMC150p
on Dec 10, 2010 at 2:09:39 am
Probably not right right place for this, but only place I could find. I hve the HMC150 and it works great. Only problem lately is two shooting events, both the same situation. Interior shots in low light. I'm getting a rythmic shift in the color from warm to a colder look. Is there something on a menue I need to turn off? I mean with so much automatic functions in this camera, that could be possible. A case of the white balance looking for a consistant light source, or something of that nature. Any ides?
Noah Kadner
Re: HMC150p
on Dec 10, 2010 at 2:49:04 am
Switch off auto white balance- balance manually.
Noah
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Canon 5D Mark II and 7D.
Chuck Bolland
Re: HMC150p
on Dec 10, 2010 at 3:28:45 am
Thank you. I am set on manual,so I'll keep looking. I noticed my white balance switch was set on "PRST" so that could maybe be the cause. I've moved the selector to "A" and will test it under low light. Thank you again.
