Panasonic HMC150 focus problem
COW Forums : Panasonic Cameras
Chad Potts
on Jul 27, 2010 at 9:32:57 pm
I've had the camera for a few months but I've had this problem happen to me a few times and I want to know if I should be worried. When I perform a tight zoom to manually adjust my focus - the focus begins to jitter in and out rapidly while a noise can be heard in the camera. When I zoom out it is fine. This only happens occasionally but enough to make me worry - Everything is set to manual. Any ideas on what I should do would be great.
Chad Potts
Guy McLoughlin
Re: Panasonic HMC150 focus problem
on Jul 28, 2010 at 2:26:07 am
This sounds like you are using the auto-focus feature and NOT manually focusing the shot yourself.
I NEVER use the auto-focus because it's way too slow to keep up. Everything I shoot is manually focused.
Chad Potts
on Jul 28, 2010 at 3:53:24 am
Hi Guy McLoughlin ,
I wish it was that simple - I keep everything on Manual - and I have a second HMC150 that does has not had this problem. It first happened when I connected my Redrock adapter...Now it has happened at least 3 times since then without the adapter. I'm taking it on a full day shoot tomorrow and I'll post what happens - anything else you think it could be?
Guy McLoughlin
on Jul 28, 2010 at 10:36:33 am
It sounds like it could be physical damage to the lens mechanism, which means you are going to have to take the camera to Panasonic and have them check it.
