Footage shot on DVX-100B: is it progressive or interlaced?
COW Forums : Panasonic Cameras
Mike Tomei
on Jul 13, 2010 at 8:45:58 pm
Hello everyone,
I have some footage from someone that was shot on a DVX-100B and captured on a Focus FS-100 hard drive in DV format with a MOV file extension. I'm wondering: is there an easy way for me to tell if this footage was shot in 60i or 30p?
Mike
Intel i7-930 2.8GHz
12 GB RAM
1 GB VRAM
Adobe Production Premium CS5
Noah Kadner
Re: Footage shot on DVX-100B: is it progressive or interlaced?
on Jul 13, 2010 at 10:01:22 pm
load into your NLE and see what it is there.... It would be either 30p, 24pA or 24p standard.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II and Canon 7D.
Learn DSLR Cinematography.
Dave LaRonde
on Jul 14, 2010 at 9:25:09 pm
[Mike Tomei] "...is there an easy way for me to tell if this footage was shot in 60i or 30p?"
After Effects can make short work of telling the difference:
  • Create a new AE project, and import the footage
  • Select ONE clip, and interpret it (File>Interpret>Main) as lower field first.
  • Use the "remember interpretation" command (also in interpret footage) on that clip.
  • Select all the other clips, and APPLY the interpretation.
  • Create an NTSC DV comp, and set the frame rate to 59.94.
When you add a clip to this comp, find a section with motion in it, and step through it frame by frame. If the motion changes on every frame, it's interlaced (60i). If it changes on every OTHER frame, it's progressive (30p).
Dave LaRonde
Sr. Promotion Producer
Noah Kadner
on Jul 15, 2010 at 12:04:45 am
you can also tell visually by going frame by frame in any editor- not everyone has AFX. :)
Noah
