Class 10 SDHC can't record PH or HA
COW Forums : Panasonic Cameras
Michael Dunlop
on May 17, 2010 at 11:51:10 pm
None of my new Adata 8gb class 10 SDHC cards will record in PH or HA. I get an error message and have to use HG. A friend with a newer HMC 150 has no trouble.
Noah Kadner
Re: Class 10 SDHC can't record PH or HA
on May 18, 2010 at 1:55:25 am
Try a different brand- not all Class 10 SDHC cards are built alike. If that still doesn't work your camera could have a problem or need a firmware update.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II and Canon 7D.
Watch Formosa- My indie movie shot with the SDX900 and finished with Final Cut Studio.
Katie Cooper
on Nov 25, 2010 at 9:53:00 pm
Hi There,
I have the same issue with the Extreme 32 gb SanDisk card.
It is also class 10 and 30mb/s
Is there a recommended brand to use with the AG-HMC-150P?
Katie
http://www.katiecooper.ca
Guy McLoughlin
on Nov 26, 2010 at 1:19:09 pm
What's the firmware of your camera?
The current firmware is 1.21, and I think it was firmware 1.19 or 1.20 that added SDHC Class 10 compatability.
I use only Patriot brand SDHC cards, both Class 6 and Class 10 with no problems at all over the past 18 months.
NewEgg: Patriot LX 32GB SDHC Class 10 Flash Card : $70
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220452&cm_re=patri...
NewEgg: Patriot IRIS 32GB SDHC Class 6 Flash Card : $75
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220444&cm_re=patri...
*** Canadians can buy the same cards from NewEgg.ca
Noam Osband
on Jul 27, 2011 at 4:34:34 pm
Is there any problem with using class 10? I just want to make sure the answer is no. I'm planning on buying a Sandisk Extreme card and the only Sandisk Extreme offered by B&H (where ill be buying it today) is class 10.
