Cardreader issues with AVCHD in Finalcutpro
COW Forums : Panasonic Cameras
Francisco Meierbach
on Apr 28, 2010 at 12:16:22 pm
Hi everybody,
I am testing a workflow for a documentary using the Panasonic HDC-SD707. The plan is to transfer the files from the SD-card to a Macbook Pro using a cardreader.
But unfortunatly that does not work. Finalcutpro only recognizes the files when I read the SD-card through the camera (connected to Macbook via USB).
If I put the SD-card in the cardreader, finalcutpro does not see any moviefiles.
It keeps saying: "folder contains not supported media or an invalid filestructure.
Any idea how I can avoid using the camera to transfer the clips ?
Thanks a lot & kind regards,
Francisco
Noah Kadner
Re: Cardreader issues with AVCHD in Finalcutpro
on Apr 28, 2010 at 10:25:53 pm
And what happens when you copy the card contents into a folder on your hard drive, then point FCP to that? Works fine for me...
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II and Canon 7D.
Watch Formosa- My indie movie shot with the SDX900 and finished with Final Cut Studio.
Francisco Meierbach
on Apr 30, 2010 at 10:06:39 am
Unfortunatly copying the files did not work.
But after hours of trying and almost giving up, I found the problem:
The card was not formatted right. Even though I had formatted it before using it in the camera, it seemed to miss something.
I formatted again, now everything works.
Regards,
Franscisco
Noah Kadner
on May 1, 2010 at 1:09:36 am
Always format cards in the camera for best results...
Noah
