HMC150 shooting to SD QT DV files?
COW Forums : Panasonic Cameras
Drew Hudgins
on Apr 21, 2010 at 1:43:02 pm
Maybe I'm over looking that stat... but is the HMC150 capable of capturing SD QuickTime mov (DV) files to the SDHC card --- much like my current workflow of using the Panasonic DVX100b to record straight to a FS-4 (those QuickTime files with time code - very nice way of working)...
... or am I basically looking at transcoding the files on that card no matter what with the HMC150?
Motivation is what gets you started. Habit is what keeps you going.
Dave LaRonde
Re: HMC150 shooting to SD QT DV files?
on Apr 21, 2010 at 1:56:23 pm
Why would you want to record in the EXTREMELY lossy DV codec when you can record in something like DVCPro 50, with TWICE the color resolution?
Dave LaRonde
Sr. Promotion Producer
Drew Hudgins
on Apr 21, 2010 at 2:03:01 pm
When I need quick turnaround - record, get it in the MBPro, rip it off to a DVD, hand over ... very RAW and unedited. The quicker, the better.
That and easy to mix with what I've captured with the DVX100b
Is the cam capable of what I originally posted?
Noah Kadner
on Apr 21, 2010 at 2:15:14 pm
If that's your workflow just get a DV camera. Otherwise it's a total waste of what the 150 can do. You could set up a droplet in Compressor so you just drop in footage and it becomes downconverted DV but again seems pointless to shoot HD if you're only expected to deliver DV footage.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II and Canon 7D.
Watch Formosa- My indie movie shot with the SDX900 and finished with Final Cut Studio.
Drew Hudgins
on Apr 21, 2010 at 2:43:50 pm
I'm looking forward to the versatility. Granted, I'll be using the other features and codecs ...
but, I was simply wandering if the HMC150 could do that.
... so it sounds like the droplet technique in Compressor is what I'm looking at?
I have a Sony HC1 and can hook that to the FS-4 but I don't like the idea of running around and capturing with that unit bumping around on my belt. There's moving parts in there... can't be good for it.
Noah Kadner
on Apr 21, 2010 at 3:35:34 pm
That's what I'd do for simplest automation.
Noah
