Tape Ticking During Record/Playback
COW Forums : Panasonic Cameras
Stamatios Dimitrakopoulos
on Oct 22, 2009 at 5:31:41 pm
Hey,
I just purchased a used DVX-100A with only 76 hours on it. I tested everything out to make sure that it fit it's "excellent condition" description and it did until I started hearing a ticking noise coming from the tape deck as I was recording. I captured the tape into FCP to see if the sound was being picked up by the on camera mics and it was.
I used my school's DVX-100's for a majority of my projects and never remembered hearing this noise or the motor during zooms so loudly. Obviously I can't have a ticking noise running throughout my audio track.
I just wanted to make sure that I wasn't being paranoid and should keep the camera. Or if I should return it/ look for a repair.
What you can you suggest?
Noah Kadner
Re: Tape Ticking During Record/Playback
on Oct 23, 2009 at 3:21:06 am
You really shouldn't be using just the onboard mics for your audio. Those are there just to prove the camera can in fact record sound. If you want good sound, get an external mic either a boom, lav or at least a longer shotgun mic for the camera. It shouldn't really be ticking either- at least not incredibly loudly.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera! Unlock the secrets of 24p, HD and Final Cut Studio.
Now featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II, and Panasonic DVX100.
Call Box Training
DSLR Cinematography Blog
Justin Netti
on Oct 24, 2009 at 6:26:00 pm
I'm having the same problem. The only solution i've found is changing the recording tape speed from SP to LP and the clicks stop. It must be an internal camera issue rather than an external audio problem. If anyone has any ideas please let me know!
