Loose Audio for 1 second between clips
COW Forums : Panasonic Cameras
Stephen Lubin
on Oct 4, 2009 at 1:27:00 am
Hello,
I wasn't sure if I should post here or in the premiere section, but anyway, I've filmed a 2.5 hour seminar with the HMC150 on a SanDisk 16 GB Class 10 extreme sdhc chip. I uploaded one of the chips data into premiere pro CS4. I never stopped recording, yet somehow there's 3 different files, each one has appeared to broken into 4 GB segments. When I put them together in premiere, there is a 1 second loss of audio at the very last second of each clip. So when it goes into the next clip, you can't hear anything for 1 second.
Everything else is working great, but how do I fix this? Is this supposed to be happening!?
Thanks in advance!!!
-Stephen
George Gio
Re: Loose Audio for 1 second between clips
on Oct 5, 2009 at 5:26:41 pm
Had same problem. licky me we shoot with 2 cam.
Now I push stop every 20 min in PH mode.
