XLR adapter
COW Forums : Panasonic Cameras
Daniel Alpizar
XLR adapter
on Aug 31, 2009 at 5:26:27 pm
Camera:
DVX100B
Mic: Azden SGM-2X XLR 2 barrel shotgun
I have an XLR microphone and I attach it to the camera with an adapter. It captured great sound at first and then it simply stopped working; I changed the batteries with no luck. I have already captured sound so I know I had the settings correct.
The only thing that may be a problem is that the part of the adapter where I have attached the microphone is not flush; it locks in, but there is a little gap where it should be flush. I can't remember if it was flush before or if it managed to capture sound in this condition too. Does it sound as if I need a new adapter and if so, what do you recommend?
Noah Kadner
Re: XLR adapter
on Aug 31, 2009 at 5:35:46 pm
I'd check the mic with another camera- if it works fine then the camera needs repair. If it doesn't the mic needs repair.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!. Unlock the secrets of the 24p, HD and Final Cut Studio.
Now featuring the Sony EX1 Guidebook, Panasonic HVX200, and Panasonic DVX100.
http://www.callboxlive.com
