• | DVX100B Audio Input 1 not working
on Aug 12, 2009 at 5:36:03 pm |
I have a DVX100Bp
Whatever microphone I plug into Input 1..it does not work.
Microphones work fine when I plug into Input 2.
I noticed in the manual a "Phantom" microphone is discussed..but never defined. Is this my issue?
thanks
• | Re: DVX100B Audio Input 1 not working on Aug 12, 2009 at 8:20:09 pm |
Phantom power (also known as +48V) is required by certain kinds of microphones to function. These are generally wired condenser mics without batteries.
If phantom power is turned off on input 1 and your microphone requires it to function, that could be your problem.
• | Re: DVX100B Audio Input 1 not working on Aug 17, 2009 at 6:52:22 pm |
Are ure sure your mic/cable are working?
If so, check the front of the camera to insure the mic/line switch is set to Mic and that your audio level knob is not in the complete counter-clockwise position.
Tim
Tim Scarpino
