Panasonic HMC-150 and FCP 2 requirements
COW Forums : Panasonic Cameras
Marty Glembotzky
on Mar 27, 2009 at 12:24:23 pm
I am considering buying the Panasonic HMC-150 before the end of the month to take advantage of the rebate offer but am concerned if my setup will support it. Have been using the HVX-200 with DV tape as of late.
I run with an OWC 250 firewire with the 9/11 chipset for my external drive. I just installed FCP 2. My hope is the below is enough info for the call to be made. Looks like a sweet camera.
Any help would be much appreciated!
Hardware:
Hardware Overview:
Model Name: MacBook Pro 15"
Model Identifier: MacBookPro1,1
Processor Name: Intel Core Duo
Processor Speed: 2 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 2 MB
Memory: 2 GB
Bus Speed: 667 MHz
Graphics/Displays:
ATI Radeon X1600:
Chipset Model: ATY,RadeonX1600
Type: Display
Bus: PCIe
PCIe Lane Width: x16
VRAM (Total): 256 MB
Vendor: ATI (0x1002)
Device ID: 0x71c5
Revision ID: 0x0000
EFI Driver Version: 01.00.068
Displays:
Color LCD:
Resolution: 1280 x 800
Depth: 32-bit Color
Core Image: Hardware Accelerated
Main Display: Yes
Mirror: Off
Online: Yes
Quartz Extreme: Supported
Built-In: Yes
Display Connector:
Status: No display connected
Memory:
BANK 0/DIMM0:
Type: DDR2 SDRAM
Speed: 667 MHz
Status: OK
BANK 1/DIMM1:
Type: DDR2 SDRAM
Speed: 667 MHz
Status: OK
Serial-ATA:
Intel ICH7-M AHCI:
Vendor: Intel
Product: ICH7-M AHCI
Speed: 1.5 Gigabit
Description: AHCI Version 1.10 Supported
Hitachi HTS722020K9SA00:
Capacity: 186.31 GB
Model: Hitachi HTS722020K9SA00
Revision: DC4OC76A
Serial Number: 071218DP0410DTG8BSJP
Native Command Queuing: Yes
Queue Depth: 32
Removable Media: No
Detachable Drive: No
BSD Name: disk0
Mac OS 9 Drivers: No
Partition Map Type: GPT (GUID Partition Table)
S.M.A.R.T. status: Verified
Volumes:
MacBook HD:
Capacity: 185.99 GB
Available: 90.89 GB
Writable: Yes
File System: Journaled HFS+
BSD Name: disk0s2
Mount Point: /
USB:
USB High-Speed Bus:
Host Controller Location: Built In USB
Host Controller Driver: AppleUSBEHCI
PCI Device ID: 0x27cc
PCI Revision ID: 0x0002
PCI Vendor ID: 0x8086
Bus Number: 0xfd
Built-in iSight:
Product ID: 0x8501
Vendor ID: 0x05ac (Apple Inc.)
Version: 1.84
Speed: Up to 480 Mb/sec
Manufacturer: Micron
Location ID: 0xfd400000
Current Available (mA): 500
Current Required (mA): 100
USB Bus:
Host Controller Driver: AppleUSBUHCI
PCI Device ID: 0x27c8
Bus Number: 0x1d
Applications:
Final Cut Pro:
Version: 6.0.5
Noah Kadner
Re: Panasonic HMC-150 and FCP 2 requirements
on Mar 27, 2009 at 5:47:19 pm
If you have FCP 6.04 or later and can run that you should have no problem with HMC150 footage- it's data rate is just a little more than DV. Though obviously a lot more efficient.
Noah
Check out my new RED Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color.
Now featuring the Lens Adapter Guidebook, Sony EX1 Guidebook,
DVD Studio Pro and How to Light Interviews.
http://www.callboxlive.com
Marty Glembotzky
on Mar 27, 2009 at 6:10:41 pm
Thank you Noah. I've been a lurker for a while, really enjoy reading your posts, very informative.
Noah Kadner
on Mar 27, 2009 at 8:46:06 pm
Thank you. :)
-Noah
