hmc150 and outputting HD in Final Cut
COW Forums : Panasonic Cameras
Donald Pollock
on Mar 4, 2009 at 1:14:51 am
We are considering buying Panasonic HMC 150s.
We edit in Final Cut.
What do we need to be able to out an HD signal?
Do we need a video card. Any recommendations on a card?
Can we record the HD signal to an HDV deck?
We have been using a SONY EX1. We love the pictures. We got an AJA card to be able to see the HD output. Now we are stuck on how to show in HD. Will we have similar issues with theHMC? The AJA card only outputs component. There is no component output in the HDV deck.
Noah Kadner
Re: hmc150 and outputting HD in Final Cut
on Mar 5, 2009 at 12:31:42 am
Pardon but what is the question? An AJA card would give you HD output with the EX1 or the HMC150. The deck or camera itself would not.
Noah
Check out My My FCP Blog and my new RED Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color.
Now featuring the Sony EX1 Guidebook,
DVD Studio Pro and How to Light Interviews.
http://www.callboxlive.com
Donald Pollock
on Mar 5, 2009 at 1:43:36 am
To clarify my one of my questions (hopefully)
I want to output in HD. I can play from Final Cut to an HD monitor through the AJA.
But I want to screen the video in HD in another location.
What options do I have? C
an I burn a blu ray disc straight from Final Cut?
Can I burn a blu ray disc from DVD Studio Pro?
Do I need to go through Encore?
Can I compress through compressor into quicktime and play back in HD from a hard drive?
If so what compression setting should I use?
What about playing out from the time line?
On a related note can I send out to an HDV recorder?
If so what kind of connection can I make from my AJA to the HDV deck?
The AJA has component out.
The HDV deck does not.
Don Pollock
Noah Kadner
on Mar 5, 2009 at 3:59:30 pm
Oh ok. Yeah you can make a Blu-Ray or you can connect a laptop or desktop directly to a projector or HD screen. I would never recommend trying to use the camera itself as a playback deck.
Noah
