toast 9 workflow
COW Forums : Panasonic Cameras
Bob Torrez
toast 9 workflow
on Jan 30, 2009 at 10:31:25 pm
Any step by step inst. for 150 footage .MTS file into toast 9
can not find export.
please help
g5 dual fcp 5.4
Thanks bt
Bob Torrez
Re: toast 9 workflow
on Jan 30, 2009 at 11:26:02 pm
Thanks...got it.
Michael Fountain
on Feb 3, 2009 at 4:24:11 am
Hey Bob,
Mind sharing your toast 9 tips? I too am a toast 9 user and would appreciate any info..
Thanks Much
Bob Torrez
on Feb 4, 2009 at 8:57:30 pm
not sure if this helps..drag your mts files into toast.
Hit the record button, there you will have choices.
I went with AIC, check your size settings etc. and export.
Import your exported files int fcp. If your sequence settings are correct, you should be able to work away...no red line or rendering needed.also make sure you are in convert in toast.
