Letterbox FCP Anamorphic settings Help
COW Forums : Panasonic Cameras
Benton Roman
on Jan 20, 2009 at 4:45:17 am
I am helping a friend edit some footage for an art video.
She shot it in letterbox mode on the DVX-100b 29.97. She captured it in FCP using the capture setting DV NTSC Anamorphic.
When I look at the quicktime is stretched out horizontally. The info says format 720x480 but the current size and normal size are 854x480. I thought letterbox in DVX-100 would just letterbox a 4:3 image.
Here is the question: To get the correct aspect ratio to edit and for output - 1. Should the clip be checked as anamorphic in the browser? 2.Should the sequence setting be checked as anamorphic/16x9?
Normally I can tell by the eye which is right, but these are abstract sculptures so I really have no frame of reference.
Thanks.
Noah Kadner
Re: Letterbox FCP Anamorphic settings Help
on Jan 21, 2009 at 3:48:16 am
Well it depends- was it shot letterbox or squeeze? This might help you get your head around the issues:
http://www.thedigitalbits.com/articles/anamorphic/anamorphic185demo.html
-Noah
Check out My My FCP Blog and my new RED Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color.
Now featuring the Sony EX1 Guidebook,
DVD Studio Pro and How to Light Interviews.
http://www.callboxlive.com
Benton Roman
on Jan 21, 2009 at 4:11:11 am
It was shot Letterbox.
Noah Kadner
on Jan 22, 2009 at 11:12:11 pm
Then it should not have been captured as anamorphic because it's not. You can simply uncheck the anamorphic check box for each clip in your bin. But this will not affect clips already placed in a timeline.
Noah
