How do you sync two Panasonic VX100s? Help!
COW Forums : Panasonic Cameras
charle goucher
on Mar 4, 2008 at 1:20:45 pm
whats the best way was to sync your footage?
i'm recording with two panasonic vx100's.
could someone give me an in-detailed description/walkthough?
i heard you can do it though the cameras? thanks!
Tim Scarpino
Re: How do you sync two Panasonic VX100s? Help!
on Mar 4, 2008 at 3:05:44 pm
If you're talking timecode, you can do do it by using the remote control and having the DVXs side-by-side.
Be sure the timecode generator is set to "free" on both DVX's and that they are BOTH set to either Drop Frame or Non-Drop Frame.
Using the Remote Control, set your desired timecode.
All should be well, though I would check from time to time to insure they are still in "sync".
Tim Scarpino
Tim Scarpino
Steve Wargo
We flash
on Mar 6, 2008 at 4:43:51 am
We use a regular flash camera.
Rewind the tape in both cameras even if it's new.
Set the TC to Record Run.
Start both cameras with a remote.
Let them run for 20 seconds.
Snap a flash on something that both cameras can see.
In post, line up the flash.
Your TC should be pretty close
Steve Wargo
Tempe, Arizona
It's a dry heat!
Sony HDCAM F-900 & HDW-2000/1 deck
5 Final Cut (not quite PRO) systems
Sony HVR-M25 HDV deck
2-Sony EX-1 HD .
