Totally screwed up frame rate issue
COW Forums : Panasonic Cameras
Todd VanSlyck
on Jun 17, 2014 at 8:44:39 pm
I've got a screwy situation here and was wondering if one of you could help me.
I borrowed a Panasonic HVX200AP P2 camera to use as a second camera to shoot a graduation ceremony.
I set the capture mode to 720p/30pn. The "scene file" dial was set to Cine V (which I didn't realize), causing it to shoot 24 fps. So somehow I shot 24 fps inside a 30p frame rate. Don't bother asking me how the hell that's even possible, but apparently it is.
As a result of this, all the footage is overcranked, so I need to somehow get it back to normal speed at 30 fps.
I don't even know how to do this, but I'm guessing it won't look purdy by the time I'm done.
Any help would be greatly appreciated.
Dell T76000 Dual 8-core 2.4 GHz
NVIDIA Quadro 2000
NVIDIA Tesla c2075
Adobe Premiere Pro CS6
After Effects CS6
Cinema 4d r12
Todd VanSlyck
Re: Totally screwed up frame rate issue
on Jun 18, 2014 at 12:48:31 pm
If anybody is intersected, I ended up solving the problem by slowing the footage down to 80%. This made it the correct speed. I exported it at that speed and am using this clip to edit with.
TVS
NVIDIA Quadro 2000
NVIDIA Tesla c2075
After Effects CS6
Cinema 4d r12
Chris Tompkins
on Jun 19, 2014 at 12:25:42 pm
You can use 24p footage in a 30p edit and not have any speed change...
Chris
