2 HPX 170 questions
COW Forums : Panasonic Cameras
Jack Niedenthal
2 HPX 170 questions
on Feb 12, 2014 at 1:56:42 am
1) when I shoot 1080i/60 and then output it as an H264 file it comes out as 29.67 fps. Shouldn't is be 60 fps as I have the settings on FCP to look at the first clip and set that as the frame rate?
2) when shooting 1080i/60 in low light, even when adjusting shutter speed, the image stays fairly dark. Any suggestions for shooting in ambient light at this resolution?
Jack Niedenthal
Microwave Films of the Marshall Islands
http://www.microwavefilms.org
http://www.microwavefilms.org/Crickets.html
iMac i7 using Mavericks 10.9.x, HPX 170 using only one 64GB card
I live on an island in the middle of the Pacific, YOU are my only resource.
Chris Tompkins
Re: 2 HPX 170 questions
on Feb 12, 2014 at 3:14:42 pm
1080i/60i is 60 fields per second or 29.97 FPS.
1080i/30p is 29.97 FPS.
The 170 is not that great in low light, you gotta bump up the gain, keep the shutter at 1/60.
Chris
