Panasonic HPX500 Menue for LCD Display
COW Forums : Panasonic Cameras
keith sandler
on Feb 9, 2014 at 5:01:47 pm
I just purchased a used HPX500. The LCD Display appears to be 4x3 while in HD mode, and also is MCR (reading the Card) mode. It says it is in AUTO in Blue, but the LCD screen is not automatically changing over to 16x9 or leterbox. Blue seems to be the "lock out" you cant change me color in the menu. Has anyone seen this before? How can I correct this. The manual says the LCD screen will automatically change over its aspect ratio when it senses it. Not happening.
Dave Festa
Re: Panasonic HPX500 Menue for LCD Display
on Mar 4, 2014 at 2:51:43 pm
Make sure the output is set for HD 1080p or 720 and check the record format is in HD as well.
