Is The HD-SDI of an HPX500 FULL HD?
COW Forums : Panasonic Cameras
peter tours
on Aug 10, 2013 at 7:02:01 pm
Besides, 720p does the HD-SDI output of the HPX500 put out full HD 1920x1080 or is it limited to 1280x1080? If the latter, does a KiPro uprez it?
Peter Tours
TnT Video Services, Inc.
Fort Lauderdale, FL
TRI EA5 1974-1977
Convergence ECS1B 1977-1979
Sony BVE 500 1979 - 1984
Datatron Vanguard 1984 - 1993
GVG VPE141 1993 - 1998
Media 100 1995 - 2006
Final Cut Pro 2005 to not too much longer
Adobe Creative Cloud
Shane Ross
Re: Is The HD-SDI of an HPX500 FULL HD?
on Aug 11, 2013 at 7:53:39 am
The signal coming out is full raster 1920x1080. Only the DVCPRO HD format is 1280x1080. If you send that signal to the KiPro, It'll record full raster, 10 bit ProRes.
Shane
Little Frog Post
Reid VanVoris
on Aug 12, 2013 at 6:12:02 pm
I believe the SD-HDI out of the HPX500 is 8-bit. The KiPro records it as 10-bit, but the 4:2:2 color space is what will count most for the keying you're trying to do.
Reid VanVoris
e-Mail: r1108@hotmail.com
