P2 no longer recognized by pc
COW Forums : Panasonic Cameras
Gavin Impett
on Jul 6, 2013 at 1:59:09 am
Hi guys,
camera is an HVX200
2pc problems, I was able to get the p2 drivers working on one windows 7 64 bit machine, but now that one has stopped working. USB2 to Sony Vegas Pro 12 and recognized by windows explorer.
Second machine win 7 64 bit, installed a pcmcia adapter, device not recognized by windows explorer or Sony Vegas Pro 12.
Swapped cables, uninstalled, reinstalled drivers, any trick to getting this to work, or do I have to consider the possibility of a dead usb port.
thanks,
Gavin
Gavin Impett
Re: P2 no longer recognized by pc
on Jul 11, 2013 at 4:34:40 pm
semi-solved driver issue, by reinstalling the drivers using the repair function, which persuaded the computer to recognize the pcmcia slot, so I can pull files that way. This did not get the USB2 connection to function again. That is still non-functional after previously working.
Baby steps. But it does seem the pcmcia card will function if you double install the drivers - meaning install drivers - expect a fail, reinstall drivers, select repair, and away it goes. Worked with two pcmcia cards on two different machines.
Good luck.
