FCP7 workflow with Panasonic AG-HPX170P
COW Forums : Panasonic Cameras
Lahoe Ku
on Jul 1, 2013 at 3:48:10 pm
Hello,
I have footage shot by AG-HPX170P in 2010.
(MXF file-DVCProHD 720p60, 960*720, 23.97f, Progressive)
But my most footage & project format on FCP 7 is
Apple Pro Res 422, 1920*1080, 29.97f.
What would be the best way to convert mxf file to fit to my project??
Look forward to hearing from experts. Thank you.
Lahoe
Chris Tompkins
Re: FCP7 workflow with Panasonic AG-HPX170P
on Jul 1, 2013 at 6:09:57 pm
You want to Log & Transfer the P2 media from the folder/hard drive into FCP.
You shot 720p/24 so that is what you have.
Try dropping the 720p material into your 1080 edit, res it up to fill the screen, in most cases this is fine. You can also, open up the 720p quicktime files in compressor and convert clips to 1080p first and then re-import them into the edit.
Chris
Lahoe Ku
on Jul 2, 2013 at 8:20:11 pm
Thank you Chris!Both way worked well.
