how to fix HPX 3700 stuck pixel?
COW Forums : Panasonic Cameras
Per Argentine
on Apr 10, 2013 at 7:41:43 pm
I just noticed that all of our footage shot several months ago has a single stuck pixel, not very noticeable luckily. I pulled out the camera yesterday and took a new shot. That stuck pixel is gone but in its place is another in the center of the frame. Anyone know how I can get rid of it on the 3700? I found an old varicam post saying to go into the settings and select something like "all data clear" and then black balancing, but I can't find a setting like that in the 3700's manual.
Jim Wilcox
Re: how to fix HPX 3700 stuck pixel?
on Apr 11, 2013 at 6:14:43 pm
Per,
We have a HPX2000 and had this issue a number of years ago. Don't know if the procedure is similar, but I have a 8 page doc that walked us thru "blemish" removal for that sensor. If you have an e-mail address I can send that to you as a starting point.
Per Argentine
on Apr 11, 2013 at 7:05:24 pm
Thanks, that seems to have done the trick!
Just in case someone else has the same problem here's the quick fix (there are more things to try if this doesn't work):
Set White Balance switch to PRST
Set Shutter switch to OFF (on the front of the camera)
Close Iris
There's a switch on the front of the camera with ABB, flick it to ABB and let it cycle til it says ABB OK.
Chris Tompkins
on Apr 12, 2013 at 1:16:19 am
You should "Black Balance" every time you change recording formats.
See pic from manual:
Chris
David Garraway
on Mar 25, 2015 at 3:56:36 pm
Jim-
I'd like to get a copy of the blemish removal procedure for the HPX 2000. My email is David dot Garraway at msstate dot edu.
