HPX500 SD output vs. KiPro downconvert
COW Forums : Panasonic Cameras
Craig Mikhitarian
on Mar 13, 2013 at 7:48:04 pm
We're shooting with HPX500 and client wants us to record 4:3 Standard Def ProRes files onto a KiPro via SDI. (The P2 recordings won't be used.)
So, we could either shoot and send a 720 HD signal to the KiPro and have KiPro downconvert to SD with center-crop, or, set-up the camera to shoot SD and send the SD signal to the KiPro.
Any ideas on which would produce a better result?
Also, is timecode embedded on the SDI signal from the camera? We're shooting with 2 cameras that would have identical TC and, of course, want the KiPro files to record the same code.
Craig
Craig Mikhitarian
ACM Productions, Ltd.
Steve Eisen
Re: HPX500 SD output vs. KiPro downconvert
on Mar 14, 2013 at 4:25:36 am
I would go HD-SDI out of the HPX-500 and set the KiPro SDI to Downconvert. Timecode is embedded in the SDI signal.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group
Craig Mikhitarian
on Mar 15, 2013 at 2:56:54 pm
Thank you for the response, Steve.
Craig Mikhitarian
