P2 Cards not showing up on desktop
COW Forums : Panasonic Cameras
Bryan Less
on Jan 23, 2013 at 3:55:18 pm
Hello all
I use a PCD20 P2 card reader. My P2 cards used to show up on my desktop as P2 icons with the PCD20 slot number. Now they just appear as mounted drives. Which means P2 formatter will not see them. Any ideas what is causing this? Could I have installed something that caused this to go away? I reinstalled P2 drivers and P2 formatter with no resolution. Thanks for your kind words in advance.
Bryan
Jeremy Garchow
Re: P2 Cards not showing up on desktop
on Jan 28, 2013 at 4:56:08 am
Use fw800 instead of USB?
Bryan Less
on Jan 28, 2013 at 9:40:51 am
I don't use anything but FireWire for video. Thanks for asking. I'm stumped too.
Jeremy Garchow
on Jan 28, 2013 at 12:47:41 pm
What OS are you running?
Bryan Less
on Jan 28, 2013 at 1:15:25 pm
A good mix. 10.6, 10.7 and 10.8 and it's an issue on all machines.
Jeremy Garchow
on Jan 28, 2013 at 3:59:45 pm
I know this is a silly question, but you do have the proper drives installed, correct?
There are different drivers for every OS. Click the proper tab at the top here:
https://eww.pass.panasonic.co.jp/pro-av/support/content/download/EN/ep2main...
Jeremy
Bryan Less
on Jan 28, 2013 at 7:00:32 pm
Yes I did install appropriate drivers, at least I think so. Thanks for pointing that out. You know I wonder if something was installed that is interfering with this? I don't know why why this could be an issue though.
