Converting 30fps slo mo to stand 24p playback - Possible?
COW Forums : Panasonic Cameras
Frank Bokoski, Jr.
on Oct 13, 2012 at 6:15:50 pm
Shot with 2 HVX200s in 720P/24PN. Unfortunately one of the cams was set for 30fps (720P/24PN). Big mistake!
So, how do I convert the 30fps slo mo footage to standard 24 for proper playback. Is this possible inside of Final Cut Pro 7? Compressor?
Please help.
1615, The GC Media Project
http://www.1615.tv
Fernando Mol
Re: Converting 30fps slo mo to stand 24p playback - Possible?
on Oct 14, 2012 at 3:00:01 pm
You can change the speed of the footage to aprox 125%
I believe in Final Cut you select your clip and go to the menu
>Modify >Speed
You won't have any audio, but you should be able to sync.
Frank Bokoski, Jr.
on Oct 14, 2012 at 9:22:49 pm
This is the solution I've chosen. It's not perfect but for my needs it will be fine.
Thanks!!
http://www.1615.tv
Eric McCarthy
on Oct 14, 2012 at 6:50:58 pm
Maybe this helps? This was posted elsewhere on the Cow:
Vincent Rosati Re: Down FPS from 30fps to 24fps GRRRRR!
by Vincent Rosati on Aug 5, 2010 at 7:41:29 pm
Generally, using default methods to reduce framerate from 30 to 24fps will introduce an awkward cadence to your motion.
I haven't had to do this for some time, but I don't recall there being a 'correct' way to do it in Premiere without a plugin.
I always did this in AE with Twixtor. Instead of simply dropping frames it would redraw frames. I believe that AE now has this function in the default installation.
I'd look through the After Effects archives. I think Andrew Kramer has an AE tutorial for changing framerates in AE, it might be searched by 'frame rate', of ' time remapping' or something.
http://library.creativecow.net/articles/kramer_andrew/fps/video-tutorial.ph.....
Vince
Let us know if you come up with a solution!
-Eric
