Is the AG-HVX200P Windows Compatible?
COW Forums : Panasonic Cameras
Anne Richardson
on Aug 9, 2012 at 9:48:45 pm
I have an AG-HVX200P and I cannot download the video since I got Windows 7. Panasonic told me it probably wasn't compatible and to use a P2 card. Would this solve the problem? I'm thinking that I wouldn't ever record more than an hour at a time. Would 16GB be enough?
I just recorded a video (the one that I can't download) and the sound is horrible. There is so much room noise. It sounds like an echo chamber. What am I doing wrong?
Anne
Chris Tompkins
Re: Is the AG-HVX200P Windows Compatible?
on Aug 10, 2012 at 3:20:19 pm
so much missing info here.
Did you try hooking the camera to the computer?
Was your footage on Tape or Card?
Do you have a Card reader?
Have you installed the P2 Drivers for your op sys?
Do you have a mic?
Chris Tompkins
Video Atlanta LLC
Anne Richardson
on Aug 10, 2012 at 3:23:39 pm
Yes, I hooked the camera to the computer via the firewire cable. I was able to get "device control" in Premiere CS4, but no audio or video.
Was your footage on Tape or Card? Tape
Do you have a Card reader? No
Have you installed the P2 Drivers for your op sys? No
Do you have a mic? Only the mic on the camera.
Chris Tompkins
on Aug 10, 2012 at 3:37:56 pm
OK, so set your video specs in premiere to match what you shot.
DV NTSC 48k for example.
Chris Tompkins
Video Atlanta LLC
Anne Richardson
on Aug 10, 2012 at 5:35:26 pm
I don't know what I did wrong the first time, but I started with a new project file and it worked this time!
