HPX500 Output Question - ASAP Kinda Thing
COW Forums : Panasonic Cameras
peter tours
on Jun 9, 2012 at 1:19:47 pm
Is it possible the analog component output of the camera, which we use for monitoring, can be different from the image being recorded on the P2 card?
If so, is there an adjustment? I am assuming the monitor is properly calibrated, but it isn't here yet. If it's not I know that's prbly the issue. If the monitor is properly calibrated, back to having only the analog component output for measurement and can it be trusted?
Peter Tours
TnT Video Services, Inc.
Fort Lauderdale, FL
TRI EA5 1974-1977
Convergence ECS1B 1977-1979
Sony BVE 500 1979 - 1984
Datatron Vanguard 1984 - 1993
GVG VPE141 1993 - 1998
Media 100 1995 - 2006
Final Cut Pro 2005 to infinity and beyond!
Chris Tompkins
Re: HPX500 Output Question - ASAP Kinda Thing
on Jun 10, 2012 at 3:24:44 pm
It only outputs what your camera settings are and what you are recording.
The only different option is to "downconvert"
You can be shooting HD and video out a downconverted SD 480i signal.
Chris Tompkins
Video Atlanta LLC
