Corrupt .MXF File.... anyone care to take a look?
COW Forums : Panasonic Cameras
Jo Goderstad
on Jun 4, 2012 at 11:17:11 am
I have been given some .mxf files that will not play... i encoded one of them into .flv file via adobe media encoder and its now playable with fully working audio but black screen... i don't know anything about this stuff but wondering if any of you can take a look at the file and see if its possible to rescue video.. thanks! Its not a very large file.. 27mb.
been doing some googling and trying to figure it out myself and ended up with a lot of threads on here. Im also on Windows 7 and most of the stuff that can fix this is MAC based?
file: http://www.4shared.com/file/UI68xZ8F/00018X00.html
Shane Ross
Re: Corrupt .MXF File.... anyone care to take a look?
on Jun 5, 2012 at 3:34:25 am
MXF from a P2 camera? Did they give you the FULL card structure? Or just loose MXF files?
Shane
Little Frog Post
Jo Goderstad
on Jun 5, 2012 at 10:29:26 am
yes from a P2 camera, and i actually downloaded the files myself from the camera.. do i need all the folders and stuff on there? if so, i can get that too. no problem.
Shane Ross
on Jun 5, 2012 at 4:57:49 pm
You need all the folders and stuff. Everything. Most NLE's won't work if you just snag the subfolders. Make a new folder...name it...copy all the contents of the card to that folder.
I have a workflow tutorial on this:
http://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
The whole process is for FCP 7...but the first 2-3 min pertains to backing up the card for ANY NLE.
Shane
Little Frog Post
