HPX 370 HD-SDI to HDMI Converter
COW Forums : Panasonic Cameras
Steven Brown
on May 31, 2012 at 6:11:25 pm
I have a Panasonic HPX 370 and want to have my clients view it on a 24" LCD with HDMI input. I bought a HD-SDI to HDMI Converter and it won't work. The camera says SDI output on the BNC, it really is HD-SDI output? Am I missing something?
Ian Liuzzi-Fedun
Re: HPX 370 HD-SDI to HDMI Converter
on Jun 2, 2012 at 7:03:29 pm
Some grammatical errors seem to be interfering with your message. I suppose we could start by what format you are shooting in, if the Sdi output is set to down convert, and what converter you bought
Mark Walleman
on Jun 2, 2012 at 7:30:46 pm
Most HD-SDI to HDMI converters "like" 1080i or 720p as the input format. Some I've used will accept SD-SDI, but for some reason the output is double-letterboxed. Some converters also have limited frame-rate compatibility. I'd recommend setting the camera to either 1080i or 720p @ 59.94.
Mark D. Walleman
Relay House Inc.
