P2 problem
COW Forums : Panasonic Cameras
James Carroccio
P2 problem
on Mar 27, 2012 at 10:09:29 pm
Please help,
I import p2 files in fcp (5.1.2) and it appears, but the moment I click and drag the vid to the queue, the status gives me an exclamation symbol in red.
It ingest sd vid fine, but will not que my 720p.
I havent tried ingesting anything on my iMac g5 in a couple years, and ever since I upgraded to s ow lepord my rather old Fcp is touchy.
Thank you in advance.
James
Camera Operator/Production Tech
Chris Tompkins
Re: P2 problem
on Mar 28, 2012 at 10:36:44 am
Can you walk us through your process a bit?
Did you transfer all the cards contents to the computer first?
(And hopefully back it up)
Did you L&T the P2 Media into the edit?
Oh wait, you're version 5??
You have just the import option correct?
Have you viewed the tapeless workflow tutorial here on the cow?
Chris Tompkins
Video Atlanta LLC
James Carroccio
Re: P2 problem
on Mar 29, 2012 at 3:30:56 am
When I go to import-
There is a special option for Panasonic p2
The video content appears in the window but when I import it, it remains idle and ! Symbol Appears (as if it can't finish uploading)
Log and transfer is A Ok with Sd content
Does p2 work well with the new FCP X?
I need to get new software.
Thx for your help
James
Chris Lehmann
Re: P2 problem
on Apr 12, 2012 at 8:18:01 pm
I'm using FCP7 so I'm not sure if this applies When I have that exact same problem I go to the little gear icon in the Log & Transfer window and toggle "Remove Advanced Pulldown and Duplicate Frames" under Preferences which always fixes it. Don't know why, but it works.
