timecode distribution
COW Forums : Panasonic Cameras
Paul Rozon
on Feb 2, 2012 at 7:59:52 pm
I need to have matching timecode on multiple cameras (hpx 500) and iso decks (Kipro)(P2 Panasonic 2500).
We have an audio mobile truck coming in (pro tools rig)who will be generating the LTC from Telcom Research – T5010. This unit outputs ballanced XLR. All my video gears TC inputs are BNC connectors.
What kind of DA do I require in order to feed all my cams and decks from this single XLR ballanced line?
Any input would be appreciated.
Ian Liuzzi-Fedun
Re: timecode distribution
on Feb 6, 2012 at 10:03:41 pm
You can do this the cheap way which I do all the time and it works fine. Adapt the xlr to bnc using a cable and feed that to a regular audio da. Just make sure there Is no distortion and you should be good to go. You can also use a y splitter but at long distances that might be a problem
