Diconic battery problem?
COW Forums : Panasonic Cameras
Philip Fass
on Dec 19, 2011 at 6:45:53 pm
I have a Dionic 90 battery, not used for a while, that seems to take a full charge according to the LCD panel. But my HPX370 is giving me the steady warning light, high-pitched sound, and momentary viewfinder indication of a low battery. Can the battery's panel give misleading info...ie, could it seem alive but be dead?
Chris Tompkins
Re: Diconic battery problem?
on Dec 19, 2011 at 7:35:31 pm
And the camera settings in the menu match your batt type?
Chris Tompkins
Video Atlanta LLC
Philip Fass
on Dec 19, 2011 at 8:28:54 pm
It won't power the camera long enough to set anything. The warning light and sound stay on for about 5 seconds, then it shuts off.
Steve Eisen
on Dec 19, 2011 at 8:47:00 pm
How old is the battery? Do you keep it on the charger at all times? How many hours does the Dionic indicate on the side? Do you have any error messages on the battery?
All but one of my dionics have died. Most well over 5 yrs. old. The one that still works has always remained on the charger.
If you need a replacement battery, take a look at this website. I've been using their batteries after my Dionics starting dying well over 5 years ago.
http://www.videotechsupply.com/
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Philip Fass
on Dec 19, 2011 at 9:18:08 pm
Thanks. Will those charge on my AB charger?
Steve Eisen
on Dec 19, 2011 at 11:16:20 pm
No. You will need a new charger. Then again, I haven't tried charging them on an AB charger.
Steve Eisen
Vice President
