Difference between FILM CAM and VIDEO CAM?
COW Forums : Panasonic Cameras
Jack Niedenthal
on Nov 18, 2011 at 5:01:47 am
Is there any difference in the video quality between FILM CAM and VIDEO CAM when filming in say 720/24pN?
Can you film some scenes using FILM CAM and some using VIDEO CAM in the same project, or will it not look good?
For example, film some slow motion with the FILM CAM and combine it in a scene that uses VIDEO CAM.
Jack Niedenthal
Microwave Films of the Marshall Islands
http://www.microwavefilms.org
iMac i7 using Lion 10.7.x, HPX 170 using only one 64GB card
Steve Eisen
Re: Difference between FILM CAM and VIDEO CAM?
on Nov 18, 2011 at 3:32:13 pm
There is no difference in quality. Make sure if you are in Film mode shooting 24pn or 30pn that your frame rate is set to default. If not, you are either under or over-crancking your footage and there will be no audio recorded.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Jack Niedenthal
on Nov 18, 2011 at 8:31:30 pm
Thanks Steve. And if I wanted to do a typical slow motion scene, I would create a Scene File and set Operation to Film Cam and the frame rate to 48 if shooting in 24pN?
Jack Niedenthal
Chris Tompkins
on Nov 18, 2011 at 9:46:06 pm
Jack, You need to spend some time with your new camera.
You want VFR to shoot slo-mo in cam. Page 31 in the manual.
Chris Tompkins
Video Atlanta LLC
